Assistance required with Creating/Building a Site Map
how do you create a site map?
3
people have this question
I have this question, too!
Tell me when someone answers.
Inappropriate?Hi "Fantasweets"
We still need to work on a feature to allow you to do this.
I should mention that when you publish your site we submit it to Google on your behalf, so it might be that we have already done what is needed.
Let me know if this solution is acceptable to you.
Best wishes
Monique
Inappropriate?Hi Swizz,
Welcome to SynthaSite, we're glad you joined us! We would like to give
you all the information you need to help you build your site. We strive
to make SynthaSite as easy to use as possible, and we are here to help
you over the initial learning curve and support you when you need us.
Here are the initial steps after you log in:
1. Click on "Create New Site". You will be prompted to give your site a name.
2. Select a style. Your site will be given a default style, but you can
change it by clicking on the "change style" button in the tab at the top of your screen.
3. Drag and drop widgets from the side bar on the right of your page
and start editing them to add content such as text, images and videos.
4. If you want to make a new page click on "New Page" (the third button from the right above your page).
5. When you are happy with your site click "Publish" and you will be
taken through the steps to publish your site. Your site will be live as
soon as you publish it.
6.
If you want to make changes to your site after you have published it,
it's very easy to do, just log in to your account and open your site.
You will be able to make all the changes you want. Don't forget to
republish your site at the end of each session.
For detailed step-by-step instructions please check the tutorials, video tutorials and FAQs which you will find in our help menu under "Support" as well as on the support section of our website. Here is the link: SynthaSite Support.
My suggestion is that you start creating your site using our tutorials
and videos as a guide. Then, if you run into any particular problem,
you are welcome to email us and we will do our best to help you
Regards,
Kershnee
Loading Profile...
EMPLOYEE
EMPLOYEE
