Get your own customer support community
This topic was archived on 09/07/09
Archived because: out of date
Banner problem.
ok so ive had a site for a while that i havent edited, and yes ive reported this problyem before. but i need it to be fixed so i can add the banner to the page.
As i was saying, i had a site and its already put together but we were waiting for the summer to reopen it, now when i go to look at it to edit it and stuff i remembered that this layout wont alow me to change the banner anymore :( can you please fix this? i need to be able to add the banner and i already have the web to fit this layout not any others.
the layout im using is for yola.com and its called "Midnight". pleas fix this :) thank you for your time.
(we dont need it fixed right away so take your time. if you need more info please post a coment and i will reply, usually right away.)
sad I’m sad cause it dont work
Inappropriate?
1 person has this problem
The company marked this problem solved.
See the changes made to this problem
User_default_medium
