Getting fed up with Yola.
Why do I keep loosing pictures of my web site. For example
:http://www.ccrcmodels.com/ic-planes.php This isn't the first time this has happened.
Regards Colin
Regards Colin
person has this problem
I have this problem, too!
Tell me when someone solves it.
The more people who report this problem, the more it gets noticed.
The company marked this problem solved.
Inappropriate?Hi piestalker,
Its hard to say exactly whats wrong with your site.
The site seems to contain source code that is not native to Yola -
Have you copied in content from another site or source?
The images that do not appear on the page you link have this URL
http ://www.yhmodels.com/pro/1200954103111.jpg
Perhaps the site that hosted them has removed them.
I would suggest copying any text first into Notepad then into Yola and any images you use should be saved to your computer and then uploaded to your filemanger (i.e. hosted by you)
Hope this helps
Lee.
Inappropriate?Lee has given a very good suggestion.
I had a look at the page and it also looks to me like the images where copied and pasted from an external source, rather than uploaded to your Yola file manager. You have other images that you have added as resources hosted on your own site (by uploading them directly) and those seem to be displaying as expected. You should use the same method for all your images.
If this doesn't solve your problem, please let us know. -
Inappropriate?Lee's suggestion is right.I'm a total (you know what)head. Nearly all my pictures are coppied from over sources. I'm going to have to replace the lot.
The site that hosted the vanishing pictures is being rebuilt.
Thought I was being clever and saving time, I'm a stupid %%%%.
Thanks for your help. -
Cut yourself some slack! Perfectly natural thing to do! I am just glad Lee was able to solve your problem! They don't call him The Duke for nothing :)
Loading Profile...
CHAMP
EMPLOYEE
