I have 436 html problems according to WC3, how do I fix them?
when I go to a markup validation site called WC3, it tells me I have 436 html problems. This web page is I belive just a HP help page so they do not offer to fix the codes. Do you know of any sites that do this service or can you all help me to get these fixed?
person has this question
I have this question, too!
Tell me when someone answers.
Inappropriate?Hey Brett,
Can you give me your site address so I check out WC3 to see what th errors are?
Thanks
Connor
Hi Brett,
Alot of the errors seem to be your use of Capitals in html. Html is meant to be all lowercase and any capitals will cause errors. If you fix these than it will greatly reduce the amount of errors. -
Inappropriate?Thank You I will give it a try, You are very Nice! Wish there were more people like you out there!
I’m thankful
Hi Brett,
There stil seems to be alot of capitalized tags, such as p,span,font,font-size, and many more. Once you fix all of these it should fix alot more of them. -
Inappropriate?Hi Brett,
1 of the errors i see is you have 3 or 4 meta contents on the same page.
1 is enough.
If you use firefox and windows this is a great tool for spotting html errors https://addons.mozilla.org/en-US/fire... -- i would highly recommend you download it and use it.
Lee.
Loading Profile...
CHAMP
CHAMP
