What is an easy way to add an interactive calendar?
I have looked at the posts about adding an interactive calendar and I have not been successful based on the posts I have read. I have added a calendar but could not modify it. I have created a personal google calendar and pasted the html but now the website just spins while trying to load so I delted that. Any specifice directions you can give me to make this process easy would be appreciated.
person has this question
I have this question, too!
Tell me when someone answers.
Inappropriate?Hi Dennis,
The Google calendar should work - could you let me know which directions you followed so that I can find out why it's not working?
Another alternative is to use Appointment Plus or Genbook - the steps are on this link: http://www.yola.com/customer-support/...
I tried it both ways. I added a widget and selected Google Calendar. Then on the bottom of the pae it showed it was opening the page with a green progress bar. After the bar was completely green it still showed the file trying to load. After a half hour I deleted it.
I tried doing it by adding the HTML but the same issues occurred but this time it said it was trying to load the widget which it did not do either. -
Thanks for coming back to us Dennis. Unfortunately, it's difficult to say why it's not working if you've removed it. If you could add it back, I can definitely take a look for you. Could you also let us know which browser you are using?
Google Calendar has all the steps on this link: http://www.google.com/googlecalendar/.... You also need to make sure that your calendar is made public. (I did test on one of my sites and it does work - I was using Firefox as a browser). -
Inappropriate?Marije, I have spent all morning working on this. I found another calendar at Keep and Share Calendar and I was able to load it on my website. This one seems to be working without any problems and it is verily easy to use and update. The instructions for adding the html was easy to follow and they seem to have a lot of other functions that might be of value in the future.
I’m much better now
Glad to hear it Dennis, I'll be sure to check them out - I've never heard of them before :)
Loading Profile...
EMPLOYEE
