"there was a problem adding your payment method"
  • Updated 7 years ago
  • Solved
Hi,
I've tried several times on two different days to change my billing information. My credit card works with other websites, but here I always receive the message, "there was a problem adding your payment method." Can you help?
Thanks,
Erik
Photo of Erik Soderberg
Erik Soderberg
  • 7 Posts
  • 1 Reply Like
Posted 7 years ago
Photo of Stefan
Stefan
  • 4448 Posts
  • 190 Reply Likes
Hello Erik
Did I get you right that you'd like to edit one of your existing payment methods in your My Yola? This may currently result in an error. What you'd need to do is to remove your old payment method, and add your updated payment method newly. I hope this is not causing too much of an inconvenience.
Please let me know if you should still encounter problems adding your payment method, or if you're trying to add an additional payment method.
Erik Soderberg
  • 7 Posts
  • 1 Reply Like
Stefan,
Thanks for the reply. Neither method works: deleting or adding. I tried these before and I've just tried again, and got the same response every time. What else can I do?
Erik
Photo of Jackie
Jackie
  • 640 Posts
  • 35 Reply Likes
Hi Erik,
Stefan asked me to review your payment attempts, and it looks like you can't add a card because your IP address and location do not match. I remember that you had the a similar inquiry earlier this year.
I have added your location to our safe list. Could you try adding the payment again and let us know if you are successful or not?
Thank you!
Erik Soderberg
  • 7 Posts
  • 1 Reply Like
Jackie and Stefan,
I believe you fixed the problem, Jackie. I bought a computer in the US and now I'm using it in Brazil, so this was probably the problem.
Thanks!
Erik
Photo of Jackie
Jackie
  • 640 Posts
  • 35 Reply Likes
Thanks for the update Erik, we are pleased to hear you were able to make your payment!
