Adjust column/layout width possible?
How can I change the layout widths? I want to get one column smaller to make a room for a larger column. I used widgets to add materials but it looks funny with a large gap at the middle. See http://uthav.yolasite.com/about-us.php to know what I mean.
Photo of James
James
  • 1 Post
  • frustrated
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hello James,
You can use a Column Divider Widget instead of the split page layout. What you'll need to do is change the layout to 1-column and then add a Column Divider Widget to your page. You can add other widgets into the Column Divider Widget as well as more Column Divider Widgets to create more columns.
I hope that helps!
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Oops - I forgot to say that you can drag the middle bar of the Column Divider Widget to the left or right to resize a column.
