Banner Ad Problem
  • Updated 10 years ago
My friend has a banner ad for her website that I would like to add to mine. She has it saved in a Photobucket account. When I copy the html code, rather than sending me to her website, it sends me to the Photobucket site. She has she has her banner ad on other websites with the same html code and it goes directly to her site. Any ideas if Synthasite requires something else?
Photo of Katie
Katie
  • 205 Posts
Photo of Justin Urich
Justin Urich
  • 14 Posts
Katie,can you copy and paste the HTML code provided?
Photo of Katie
Katie
  • 205 Posts
Here it is:
Photobucket
Justin Urich
  • 14 Posts
Katie,
I misdirected you...could you please put some kind of barrier around the code so it inactive....I'm just trying to see the HTML code you have so maybe I can help..put "//" before and after the code
Photo of Katie
Katie
  • 205 Posts
here it is:Photobucket
Not sure how to put a barrier, we will see if this worked. Thanks for your willingness to help me!
Photo of Katie
Katie
  • 205 Posts
Nope, still won't just show the code. What kind of barrier should I put?
Photo of Katie
Katie
  • 205 Posts
"//Photobucket//"
Photo of Katie
Katie
  • 205 Posts
I have an idea, click on the link and it will take you to the photobucket site I mentioned. Look at the codes available to copy and you will see the one I chose that is not working correctly. It is under the HTML code option. That should work!
Photo of http://www.lifeingeneral.synthasite.com
  • 271 Posts
  • 2 Reply Likes
Maybe try using !-- at the beginning and end of your code --! See if that makes a difference...Though make sure the --! is still within each bracket.
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi L.i.G - if it helps (and for future!) to stop the code from being interpreted, use <!-- and --> on either side
Photo of Katie
Katie
  • 205 Posts
a href="http://s149.photobucket.com/albums/s5..." target="_blank">Photobucket< and > off the ends. Let's see what pops up
  • 271 Posts
  • 2 Reply Likes
Hi Marije! How you going? Hope you're well. I was wondering about the --> instead of the extra --! Thanks for the heads up.
Photo of Katie
Katie
  • 205 Posts
Now that we see the link does anyone know why it goes to Photobucket and not to the website?
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Hi Katie,
The picture goes to the photobucket website because that's the link that has been added to the image. Try these steps:
1. Copy and save the image (try right-clicking and saving) and then upload it to your site
2. Add it to your page using the image widget
3. Click on Properties on the tab on the right
4. Click on 'Choose a Link' and add the URL to your friends site under URL (External).
Hope that helps!
Photo of Katie
Katie
  • 205 Posts
Marije:
It worked!!! Thank you so much for all your help. I am a happy gal. Have a good night
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Glad to hear it!
