Banner Problem...Help :S
  • Updated 10 years ago
Hello again!
I started another new website in addition to my teen mother's website, called Culinary Cupcakes. I was just wondering, I used a template that has a changeable banner...but I am having difficulty removing the text at the top and it goes over top my banner...
see for yourself: http://CulinaryCupcake.yolasite.com
How do I fix this!?
Photo of MomnovationTM
MomnovationTM
  • 25 Posts
  • Hopeful
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello Dynamic Mom,
If you click on that text in the banner area and delete it and put a space in the box using the space bar it will remove any text.
Give this a try and let us know if you have any troubles.
Kind Regards,
Emmy
Photo of Mayank Nehru
Mayank Nehru
  • 87 Posts
  • 1 Reply Like
Hi Dynamic Mom
Another thing you can do is got to edit menu option and take out all pages out of the menu.This will also solve the problem.Hope this helps you
Photo of stormydaycrafts.com
stormydaycrafts.com
  • 110 Posts
  • 1 Reply Like
wouldnt it just take all your pages off?
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello,
I don't believe that DynamicMom was wanting to take the pages out of her menu. The Header Text and the menu items are separate pieces. If you take the pages out of menu that won't remove the text from the banner area. Hope this helps!
Mayank Nehru
  • 87 Posts
  • 1 Reply Like
Just take all your pages out of menu.You can still use a horizontal menu like I use on amayanknehru.yolasite.com. .If you want help with that ask me.Also you can alternatively change from this style to a style which has menu on the right or the left instead of top.
