Being able to edit the head section of my page using Meta tags.
  • 2
  • Updated 6 years ago
Hello Yola team.
I would like to add some HTML (Meta tags) to the section of my page. It's basically lat./long. information for GeoURL to use to locate me.
GeoURL instructions,
Add the following meta tags to the section of your web page:
Note: If your site uses frames, you must add the meta tags to your top-level page which contains the — we will not check the contents of your frames.
Thank you in advance for any assisance you can provide.
Regards,
Dan
Photo of DanS
DanS
  • 13 Posts
  • 1 Reply Like
  • undecided
  • 2
Sanja, Official Rep
Hi Dan
Unfortunately, we do not have access to the head in our site builder.
However, what you can do and what seems to have worked is to simply drag an HTML widget box over and paste in your code. Then, place the HTML box high up on your site.
Hopefully that'll do the trick for you.
Photo of DanS
DanS
  • 13 Posts
  • 1 Reply Like
Champ, I did as you suggested and it worked great! I'm glad I asked and found someone that had the answer.
Thank you and best regards,
Dan
Sanja, Official Rep
You're very welcome Dan and I'm glad that this worked out for you! =)
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi Dan
So glad Littleus's suggestion worked for you! (Thanks again, Littleus!)
There is a feature request to make it possible for customers to edit the HEAD section of the page for the ability to insert various metatags. Hopefully we can accommodate this in future. In the meantime I am glad that you have a solution.
Photo of ksc0304
ksc0304
  • 3 Posts
Hello i need the same type of thing although i am using this for a php login script with cookies. I need to have the website check the user otherwise they can accsess all of my files (Programs i will be selling) . I cannot use the yola login page as i need custom logins for each custermer
Photo of Stefan
Stefan, Official Rep
  • 4448 Posts
  • 190 Reply Likes
Hello ksc0304
I'm afraid to tell you that you cannot use php files with Yola. We don't offer membership/visitor logins at the moment either.
Please see this thread for more information on memberships: Membership.
