BLOG PROBLEMS!!! HELP YOLA!!!!
  • 2
  • Updated 7 years ago
  • Not a Problem
help!!!!!!!! i can't figure out what's wrong with my yola blog!!!!!!! i can't put comments on it! yes, i followed all those steps to enable comments using discus... i pasted my code, 2nd box all that...i published my site.. but if you go to my blog, there is no place where you can type a comment or anything. it just says well look at the picture. that's what it looks like if you click on a topic. it has our post but i don't get the bottom part. and then if i click on one of the links at the bottom, it takes me to http://disqus.com/overview/ or if you're not signed in, it takes me to the discus home page. i just want people to be able to leave comments on my blog! please help. and if you wanna look at it for yourself go to www.reflectionglothing.yolasite.com/b... thanks! please help me yola!!!!
Photo of Reflection Clothing
Reflection Clothing
  • 2 Posts
  • confused
  • 2
Photo of jeremy
jeremy
  • 1349 Posts
  • 90 Reply Likes
Hi there Reflection Clothing,
I think you posted the wrong link to your site - is your site http://reflectionclothing.yolasite.co... ?
It looks like you didn't copy and paste the code correctly - it is showing some of the code which isn't right. See:
When copying the code I would suggest using CTRL A and CTRL C to select all and then copy all.
Please let us know if you have any further trouble with your blog.
Reflection Clothing
  • 2 Posts
thank you guys!!!!!!!!!! it works great now!!!!
Photo of Laura Thomas
Laura Thomas
  • 4536 Posts
  • 211 Reply Likes
That's wonderful, thanks for reporting back that it worked!
Photo of beulah
beulah
  • 1 Post
same problem!!!! i have a blog that no one can blog on. im changing from yola. ive just created a new blog site
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi Beulah - I am sorry you are experiencing this issue. Please can I have the URL of your site so I can investigate further.
Photo of Stoneboy's Ps
Stoneboy's Ps
  • 1 Post
I am having the same problem!I can't post any comments!What can i do to fix this?I am also having another problem!The word "null" is appearing under all my posts!I do not know why!
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello Stoneboy's Ps,
I'm sorry you are having trouble with this. Can you tell me what your URL is so that I can have a closer look.
Thanks,
Emmy
Photo of Hisham Akhtar Ali
Hisham Akhtar Ali
  • 1 Post
option to create blog in yola is not available.
only create a blank page option is available.
my site is:- http://www.hishamakhtarali.yolasite.com
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello Hisham,
The Yola blog has been withdrawn as a service for new subscriptions since the last half f 2012. Yola are recommending that people create their blogs with Tumblr as a more suitable alternative. You can also bring in other externally created blogs with iframes which has worked well for a number of users.
