Blog title fonts & spacing of posts
  • Updated 10 years ago
How can I change Blog posts Title font and color? Also is it possible to add more space between posts as they seem crammed. Thanks
Photo of curiousmonkey
curiousmonkey
  • 3 Posts
  • confused
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Can you post a link to your site? I would like to take a look at the spacing issues you are referring to.
Unfortunately the title font and color is set by the style and cannot be changed.
curiousmonkey
  • 3 Posts
http://thecuriousmonkey.synthasite.com/
I also wanted to change the font color of the post title but didn't find from where.
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
I see what you mean. All the issues you refer to: spacing, color and font, are attributes of the style and can't be changed. The only option is to use a different style. However, I can see that the style you are using at the moment fits in very well with your site, and it would be a pity to change it. You will have to decide which you are more concerned about, the style or the font of the blog post titles. I am sorry I don't have the ideal solution for you.
curiousmonkey
  • 3 Posts
Ok then. Thanks a lot for your interest.
