C Compiler help? Does it exist?
HELP!!! Been trying to install a C Compiler on Linux for about 18 hours straight, I've had no sleep.
No, I don't want to take up your time since this is Yola, so if you could just point me in the direction of PEOPLE I can talk to about this particular topic, please do so.
If you're willing to help me with this in this Yola forum, please say so and I'll tell you my specific problems. Thanks guys!
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
  • http://youcanneverbetoosmart.com and I'm tired
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi Donald
The only thing I could do here is google for a forum where they are discussing this topic, and I don't even know enough to know if it is a good forum or not.
If anyone does know if a good forum for C Compiler/Linux help I am sure they will tell you, but your time may be better spent by doing some research on what else is out there.
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
lol, I've done researched, they all explain it as if you're an expert at Linux or can read their minds as to how to do the "unexplained" steps to get to the "explained" steps.
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Well then you know more than I do, sorry I can't help!
Photo of Kevin
Kevin
  • 475 Posts
  • 29 Reply Likes
Try code blocks, it's great!
http://www.codeblocks.org/downloads/26
Photo of SilverX
SilverX
  • 492 Posts
  • 40 Reply Likes
And if you are installing something which require root admin login, make sure that you type "su" in Terminal first.
