Changing background to transparent. - HELP!
Hi, Here i am again. Asking all of you for your generous help.. ;) Seriously, i would like to ask for your help for my website. My website's url is http://nativeproducts.yolasite.com/..... my problem is that i wanna remove the white background color of my website and transform it to transparent so that the only background i have is the rattan. I have included a snapshot image of what i mean to make things clearer. Thank you all. here's my email address samsoft9390@gmail.com.....
Photo of Samuel Reu Delfin Flores
  • 6 Posts
Photo of Brandon
Brandon
  • 243 Posts
  • 33 Reply Likes
Hey Samual,
Please paste the following code in an HTML widget:
<style type="text/css">
div.content {
background:none;
-webkit-box-shadow: 0 0 2px rgba(0, 0, 0, 0);
-moz-box-shadow: 0 0 2px rgba(0, 0, 0, 0);
div.ys-banner-wrap {
background:none;
</style>
That should make the colour disappear, as well as the shadows. Your content area and banner border should be completely invisible! :)
Kind regards,
Brandon
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Thanks Brandon.
Samuel, please let us know if you need any further assistance.
Photo of ilkestonwebdesign
ilkestonwebdesign
  • 28 Posts
  • 1 Reply Like
I tried the instructions provided but it would not work. I am finding this particular CSS template of mine absolutely horrendous. I just CANNOT identify the ID that controls the background of the content widgets.
http://agra.yolasite.com/
This is my site and as you can see I have managed to use the display:none; command to switch off certain widgets. All I want to do now is make the background of the main content area transparent.
I have ended up so frustrated that I have gone and built this site with someone else's service and got the results I wanted. I am paying for Yola Silver but am not really finding it easy to work with
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi JC,
What's the name of the Style?
ilkestonwebdesign
  • 28 Posts
  • 1 Reply Like
I have changed template style and added the CSS rules to it.. and it worked amazingly. You just need to find the right template with all the customisable options. But really, seeing as CSS is a web standard, I don't see why some templates have limitations, especially for Silver subscribers.
Even Bronze offers workarounds using the HTML widgets if you cannot directly alter the stylesheet
ilkestonwebdesign
  • 28 Posts
  • 1 Reply Like
If anyone is interested, I used the template "Professional Slate" with these rules. Edit the dimensions as you see fit
#sys_banner { display: none;
div#menu {
display:none;
div.ys_header {
display: none;
div.ys_nav_wrap {
display: none;
div.post_banner_element {
display: none;
div.post_banner_shadow {
display: none;
div.page_content { background:url(http://s3.yolacdn.net/V0023261/templa...) repeat top center transparent;
background:transparent;
margin:-4px auto 0;
width:943px;
Photo of JC
JC
  • 354 Posts
  • 15 Reply Likes
Thanks ilkeston. What a performance especially as you had to have someone else assist. Am sure others will also appreciate.
Gop, you are wonderful all the help you give people. I gave up in the end and just used a plain site and then worked around and ended up with white as 'box' area for all text, with background showing around it.
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Yes. Very difficult JC. Sorry I wasn't of any help there ikeston.
Can you tell me the name of the Style? I still haven't worked that out either. Good to know in case of others coming in with the same. I can just say "probably impossible"
