Color for bacground -> differenc color text box
  • Idea
Afternoon,
can someone please advice! I would like to set my background one coillor (for example gray) and text boxes (lets say yellow)
is it possible?
i am currently using CleanSlate
Thank you in advance
www.fasthold.co.uk
Photo of Arturs
Arturs
  • 12 Posts
Photo of Arturs
Arturs
  • 12 Posts
with "coillo" i meant "color"
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
Hi Arturs,
I presume you mean change the body background to grey and all text widgets to yellow?
If you use silver add this to the CSS editor
body {background-color: #CCC;}
.sys_txt {background-color: #FFFF00;}
if you do not have a silver account add this to a html widget at the top of every page: <!--
<style type="text/css">
</style>
Currently on your site you have inline styles so the text widget styling I have left will not work as the inline style is the last rule. For example if you put a div with inline styles into a text widget the text widget will follow the inline styles of the inner div. It should make sense when you apply the styles to the site.
Lee.
Photo of Arturs
Arturs
  • 12 Posts
Thanks Lee,
i will try your advice!
