comment box not showing up
well look here
this is my homepage were the comment box should be
but its not thier,
i click on the first post on the page
then it shows up
i went to other yola sites and the comment box automaically shows up?
how do i do that?
Photo of tanveerahmed2k8
tanveerahmed2k8
  • 20 Posts
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi,
Unfortunately, in order to see the comment box, your visitor needs to click on the post. This is a drawback to our current integration with Disqus and hopefully it is something we can improve in a future release.
In the meantime here is the best solution I can suggest:
1. When editing your blog page, click the "Standard" folder in the Sidebar on the right. This will give you access to the other website widgets.
2. Drag and drop a Text Widget onto the top of your blogpage.
3. Type in an instructional message for your blog visitors. For example: "Please click on my blog posts to leave a comment."
I realize that this is not an ideal solution, but I hope it helps until we can improve this feature.
Photo of SilverX
SilverX
  • 492 Posts
  • 40 Reply Likes
Hey,
another tricky ways.
You can simply edit your blog widget's settings to do not folder posts and show 3 posts once ,
or paste disqus comment box script to the bottom of blog page.
Check examples.
http://www.eSecrets.tk
