confused over sub-domain seeks suitable response for long term solution
I've been reading about adding sub domains; which is what I want to do, and it makes sense up to a point. I believe its instruction #9 which instructs us to assign value A and for name use the sub group we wish to have appear. is that not telling me to do the same thing as I already did with the first listing? What am I not understanding here????eeks
Photo of dyercabinets
dyercabinets
  • 1 Post
Photo of jeremy
jeremy, Employee
  • 1349 Posts
  • 90 Reply Likes
Hello Dyercabinets,
I am sorry you are having this problem. What subdomain are you wanting to create for your domain?
If you are wanting to create a subdomain called "contact" (so it will read contact.domain.com) you will need to add an A record to your domain of "contact" pointing to 184.72.229.176
You can then contact us and we can assist you in publishing your site to your subdomain.
I hope this helps. If this does not solve your problem, please let us know.
