Flash Audio Player
Can someone suggest where I can find a flash audio player with a playlist ?
Currently we are using the player below ran from an XML file :
This player requires you hit the play button to get the list of audio files and choose one to play
We want to show the list as soon as we get to this page.
http://wwrcenglish.wwrc.ca/audio-mess...
Thank you
Photo of Felipe
Felipe
  • 58 Posts
  • excited
Photo of jeremy
jeremy, Employee
  • 1349 Posts
  • 90 Reply Likes
Hi there Felipe,
Unfortunately I do not know offhand of a flash audio player that is easily added to Yola.
We generally suggest the "YourMinis" widget to add a music playlist.
1. Upload your music files to your file manager.
2. Under the "Advanced" folder on the sidebar, drag and drop the "YourMinis" widget.
3. A dialog box will open up. Click on the blue link that says "YourMinis.com".
4. In the "search widgets" box, enter "Mp3 player" and click on "Go".
5. Select the 1st widget.
6. Click on "Edit me" and select "Clear playlist".
7. Click on "Edit me" and select "Add track to playlist".
8. On the widget, you'll see a box where you can enter your URL for your music file and then click on "Go". (Your music URL will look something like this: http://yoursite.yolasite.com/resource...
Replace the following:
*yoursite.yolasite.com with the site URL
*musicfilename.mp3 with the name of your music file.
9. Repeat Step 7 & 8 until you have added all your music files.
10. After you have added the last music URL, click on "Back".
11. Click on the button that says "Copy Me" (beside the "Edit Me button")
12. On the widget, click on the "+" sign to copy the embed code.
13. Click on "copy".
14. Go back to your site builder and paste the embed code into the dialogue box. Click on "OK".
15. Save and update your site.
I hope this alternative works for you or that someone can fid you a Flash based music player.
