Flash hyperlink help!!!!!!!
i need help to hyperlink a flash intro, the "enter the site" should be hyperlinked, but i converted to button, and added this code:
on (release) {
getURL("www.hpctoronto.com", "_self");
but it doesn't work, i tried the code on the rectangle which the words was written, nothing works, but it has the cursor where you were about to click a link, but nothing happens when you click it, detailed help would be appreciated, thanks.
my website is hpctoronto.com, it has the flash intro.
Photo of chipmunks.alvinchacko
  • 15 Posts
  • sad
Photo of Laura Thomas
  • 4536 Posts
  • 211 Reply Likes
I'm passing your question on to a colleague better suited to answer questions pertaining to code. Please allow 48 hours for a response.
Photo of SilverX
SilverX
  • 492 Posts
  • 40 Reply Likes
Flash has a great help about this.
M.. Make sure that you chose action script 2.
The destination should has a 'http://' prefix. Though most of us ignore it, remember that it has a weight on web sites.
Add http:// prefix to your destination link. That should solve the problem.
  • 15 Posts
nope, i tried it, didn't work
Photo of smithy
smithy
  • 1222 Posts
  • 28 Reply Likes
try puttin the code in this,
<!-- at the begining and --> at the end
Photo of SilverX
SilverX
  • 492 Posts
  • 40 Reply Likes
Hi smithy,
that quote code tags should not be used in flash action script.
That tags prevent executing code in this forum.
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi Chipmunks.alvinchacko,
I would suggest referring to the following tutorial for some assistance on this - http://www.tutorial5.com/content/view...
You might have just missed a step outlined in the tutorial.
Hope this helps!
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Your link should be www.hpctoronto.com/home.php
The www.hpctoronto.com is the Flash Intro itself so the link appears to be not working but it actually is.
  • 15 Posts
i am sorry, i posted here wrong but i checked the flash, it is correct, it hpctoronto.com/home.php
