flash intro banners HELP
i have created an amazing banner. animated with sound. its an .swf file aka a flash banner.
but it won't let me use it as a banner. says images only. the program i used did give me this code though.where do i put the code? so the file shows up in the right spot
Photo of ken
ken
  • 178 Posts
  • 1 Reply Like
  • not caffinated enough
Photo of Peter
Peter
  • 2569 Posts
  • 113 Reply Likes
Hi ken
you should have two pieces of coding. One the actual movie and 2 the embedding code.
the movie goes into the File Manager it has the file type .swf and the embed code/driver you place into an HTML placeholder on your page where you want to show the movie
I overlooked the fact that you wouldn't be able to pl;ace it in a normal banner placemark with Yola. You would have to use a style that allowed a high placement of code.
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hi Ken,
Here are the instructions for adding a flash file to your page:
1) Upload your .swf file to the File Manager
2) Drag and drop a HTML widget onto your site, where you would like to see your flash presentation, and paste the following HTML inside it:
<object width="200" height="400">
<param name="movie"value="resources/myswffile.swf">
<embed src="resources/myswffile.swf"width="200"height="400"/>
</object>
3) Then substitute "myswffile.swf" in the code above - in both places, with the name of the file you uploaded, and you should see the flash movie appear when you close the HTML editor. You'll need to play around with the width and height values in the text above, to suit your movie's needs.
4) Remember to include any folder names in the file path if your file is stored in a folder in the File Manager. For example: "resources/Flash folder/myswffile.swf"
Kind Regards,
Emmy
Photo of Peter
Peter
  • 2569 Posts
  • 113 Reply Likes
I'm not sure but I don't think that code will work for sound Emmy.
Ken can you wrap the code in <!-- and --> so that we can have a look at it?
Photo of ken
ken
  • 178 Posts
  • 1 Reply Like
followed the instructions and an epic fail occurred lol !! nothing shows up lol
Photo of ken
ken
  • 178 Posts
  • 1 Reply Like
just converted it to gif so it can be the banner gonna embed a player for the song....
http://randomchaos.synthasite.com/
let me know what ya think
Photo of Peter
Peter
  • 2569 Posts
  • 113 Reply Likes
Wow! dramatic intro.
You've done well with the page. Congratulations.
One question: The slide image sizes. They seem to be very slow in loading and I'm wondering if they would tolerate cutting back on the file sizes? If you can it may be worth while reducing the image sizes to say 50 kb/image. that should see a smoother and more rapid load of the slide.
Photo of ken
ken
  • 178 Posts
  • 1 Reply Like
actually since you have seen it lol i changed the banner to a smoother flowing one with a whole different look.
