google will not verify my site using meta tag & analytics HELP!
  • Solved
i have tried everything! followed every tutorial and post on here.
i get the following error code:
We weren't able to verify your site: http://www.designershopforyou.com/
my url is www.designershopforyou.com
and yes i have done it on google as www.designershopforyou.com & i have also tried designershopforyou.com
both have failed!
help me please
Photo of designershop
designershop
  • 1 Post
  • frustrated!
Photo of Stefan
Stefan
  • 4448 Posts
  • 190 Reply Likes
Hello Chad
Please allow 48 hours for Google to verify your website. If Google still cannot verify your site, please check the follwoing steps:
  • Make sure that you have entered the proper code into the Google Webmaster field. You only need to enter the text that is between the " " and nothing else; it will look something like this: XlBMeWkrAxWIJtD5n3C3N8Zv09QKKl3R1MaoZnssKA0
  • Make sure you clicked the "Publish to the web" button after you entered the code. This will apply the change to your site so Google can crawl it.
  • If you have done both of these things and are still not able to verify your site, you may have entered your URL in incorrectly. My suggestion would be to go back through the tutorial and redo the steps to make sure each part was done properly. Here is a link to the tutorial: Google Webmaster Tutorial.
Please let us know if none of these options solve the problem. Thanks.
Photo of Designer-Cheap For-Sale Coventry
  • 2 Posts
done it now thanks.
I signed up to google apps and that seems to have sorted and verifyed my site
thanks anyway
  • 2 Posts
done it now thanks.
thanks anyway
