Having problems with my sibuilder...not opening!!!!...
  • In Progress
This is the message i get when i try to get on and edit my site!!
"A request error has occurred : Invalid value for parameter "overwrite", "null" is not a valid boolean value.".
...Does anyone know how to fix this problem?...i m using opera because it is much faster...i m thinking that maybe this might be the problem?!
Photo of Andreea Egli
Andreea Egli
  • 1 Post
  • very sad
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hello Andreea,
I do believe that the reason you are seeing this is because Opera is not currently on our supported browser list. I would however like to test this on my end using Opera to be sure. Would you mind sharing your domain with us?
Here is a list of Yola's supported browsers:
* Firefox 3 or higher
* Internet Explorer 7, 8
* Safari 3 Beta or higher
* Google Chrome
If you are not using one of the following above supported browsers, then you may experience less than optimal Sitebuilding performance and as a result, our support will be limited. Thanks for sharing your domain with us so we can give you a 100% clarification that this is the reason you are seeing the message you are.
