headace inducing minor problems!
  • In Progress
Hello, I'm having difficulty loading up a picture gallery. It allows me to load them but then when I go the live site - the changes haven't been made, even though they were saved. Also, is it possible to delete the Header/title of a page as the title is included in my banner and it just looks strange having it twice! Thank you.
Photo of Karen Stratford
Karen Stratford
  • 1 Post
  • very frustrated
Sanja
Hello Karen,
I'm sure that together we can get these issues resolved. Once you have added your Picture Gallery Widget, did you remember to click on the green "Publish to the web" button to apply the changes to your live site? If you have done this and the gallery still is not showing, please can you share your URL so that we can take a look?
You definitely can delete your header. All you need to do is click on the page heading and use your delete or backspace key and remove the title.
I hope that helps!
