Help Across Devices
  • Updated 4 years ago
  • In Progress
Will someone please take a look at my site www.moradaridge.com on android or tablet and tell me why the serendipity template is not stretching the background across the page ? You have to look at the background settings - right now it is set to cover.
Photo of Veronica McCullough
Veronica McCullough
  • 5 Posts
Posted 4 years ago
Photo of Jen
Jen
  • 206 Posts
  • 24 Reply Likes
Hello Veronica,
Please try setting the background to Contain instead of cover.
I hope that helps!
Veronica McCullough
  • 5 Posts
Hey Jen - OK, but it got worse. You can see it now - its published.
What Im thinking is I might have broke the page so to speak-  and it might have something to do with the margin settings around some of the custom panel settings or the slider width settings. The slider pics are set at 1000 px wide.
Sanja, Official Rep
Hi Veronica,
Your slideshow could be the reason. In your slideshow maker, you need to ensure you've set up your slideshow to be responsive. The fixed width is causing your page to stay at a static size.
I am wondering if you try to add the responsive feature, the site would resize properly and as a result, show your background image.
I hope that might work for you.
