Help! Adding and sending Links
  • Updated 11 years ago
Can someone please explain to me exactly how to send my link to someone and what information I need to send?
and...How do I add their link to my website links page?
Apologies if I seem a tad dim...but I am :)
Photo of akasback
akasback
  • 36 Posts
  • thankful
Posted 11 years ago
Photo of Alex
Alex
  • 3448 Posts
  • 39 Reply Likes
1)
well for a link to be valid you must start it with
http://yoursite.synthasite.com
and tell them what page it goes to,
2)
to add their link tpo your links page is simple, just do the same thing as above!
hope this helps,
need help? just say!
al
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello Mark,
If you would like the html code to give to someone which will create a link to your site:
<!--<a href="http://yoursitename.com>Your Site Name</a>-->
What this code says is, the words Your Site Name when clicked on should go to the website yoursitename.com. Remove the <! -- and -- > at the beginning and end.
Here's how to add links to someone else's webiste to your page:
1. Drag and drop a text widget onto your page.
2. In the text widget type the words that you want people to click on (this is your link text).
3. Highlight the link text and then click on the link button (it's the 10th button from the left in the text editing tool bar, and looks like the link in a chain).
4. A link editor dialogue box will open up and you will be given 4 options. You can link to an email address, an external URL, a page on your own site or a file in your file manager.
5. Click on and edit the option appropriate for you.
You will then have a link on your page. To check that your link is working preview your page and then click on the link.
This is a brief explanation of how to add links, we have written a tutorial that shows the process in more detail. Here is the link: Creating Links.
If I can assist you further please let me know.
Kind Regards,
Emmy
