Help Again
  • Acknowledged
Hi I have a problem again with the tracking codes & now my site builder will not load please can you save my site again ?
Photo of DanielJ
DanielJ
  • 7 Posts
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hi DanielJ,
Please share your domain with us so we can assist you. Also, take a moment to review this tutorial: My site won't load in the Sitebuilder.
Make sure that you check that the Flash and Java on your computer are up to date and that you have cleared your browser's cache/cookies. (All steps are provided in that tutorial).
We look forward to assisting you with this.
Photo of DanielJ
DanielJ
  • 7 Posts
Ya its www.spongealiciousbakery.co.uk & it happened last wk it was to do with missings script on tracking codes :-)
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Thanks, DanielJ. I will need our HTML team to review this with you. They will do so the next time they are online. I am certain it will be a prompt fix. We appreciate your patience in the meantime.
Sanja
Hi DanielJ,
Thanks for your patience. I have now fixed this up for you!
