HELP! IE6 problems with preformatted text in table
  • Updated 10 years ago
When viewing my web page in IE6, all preformatted text in my table is centered--should be inline left. Looks normal in Firefox. When I cut and paste the the same HTML code into a text file and open it in IE6 from my hard drive, it appears normal.
I read through some other posts with similar problems and did as suggested by cutting and pasting code into text editor, deleting the html widget and adding a new widget. Same result.
The site is: http://cm-design.synthasite.com/resum...
Would greatly appreciate some help.
Chris.
Photo of Chris_1111
Chris_1111
  • 5 Posts
  • frustrated
Photo of Chris_1111
Chris_1111
  • 5 Posts
No, really, I got to get this thing fixed.
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi Chris_1111,
I am sorry you are having this problem. We are looking into this and will get back to you. Thank you for your patience.
Photo of KanThaiDecor
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
Very cool way to get your resume out there....On your contact page maybe add a free Wufoo form...Being able to interact right from your site would be a nice touch.....If I was still in the manufacturing sector and hiring people I would be impressed enough to contact you.Hope you don't mind my suggestion...BTW...Site looks great on Firefox and Chrome....IE7 is doing same as you say in IE6
Photo of Chris_1111
Chris_1111
  • 5 Posts
Thanks for the feedback John. I was hoping that IE7 would display correct--don't use it, so didn't know.
Thanks again.
Chris.
Photo of Christo
Christo
  • 95 Posts
  • 13 Reply Likes
Hi Chris
I think the problem is as a result of the center tag which surrounds your the table you are using to display your resume.
I have edited your html a little, and seem to have got it working correctly in IE.
Here is how I would suggest you fix it:
1.) Drop a text widget onto your page
2.) In a new window/tab, go to: http://toast38coza.synthasite.com/tes...
3.) Select the table on that page and copy (ctrl c).
4.) Then simply paste that into the text widget on your page
That should work accross IE as well as FireFox.
Photo of Chris_1111
Chris_1111
  • 5 Posts
Thank you Christo! That worked great, and I really appreciate all your time and effort.
You can remove the table from you site now.
Thanks again.
Chris.
