Help inserting product images using PayPal widget please
Using paypal product catalogue and my images are too big. What is the best size to use to have 10 to 20 images on a webpage? Do I resize using picnick save to my file manager and insert or can I resize within the paypal catalogue. Confused and frustrated!
Photo of Janet Webster
Janet Webster
  • 3 Posts
  • frustrated
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hi Janet,
PayPal only allows for 1 picture per product, unless you have created a custom online store using the picture gallery widget and custom PayPal buttons.
If you share your web address, we will be able to get a better idea as to what you are speaking of.
If you have added your pictures using a Picture Widget, you can certainly resize them from within the sitebuilder. Simply click on the image. After a red outline has appeared, locate the red box on the bottom right corner and drag you picture to the desired size.
If you are looking at adding multiple images per item, I would suggest trying out the Picture Gallery Widget which will provide you with clickable thumbnails. Not only will this keep your site very tidy looking, it will also allow your customers a more pleasant site visiting experience.
