Help me with an entry gateway :)
I am wanting to create an "entry gateway" similar to the one found on this site: http://www.melissamastersphotography....
I wish to have one section where they can click to enter my yola site www.statumphotography.com and another where they can enter my blog (non-yola.)
I'm not really wanting to create a brand new site with link's like I've seen mentioned on here before, I do want to be able to manage it all in one place. Thoughts? Ideas? :)
Photo of Kym Statum
Kym Statum
  • 9 Posts
  • 2 Reply Likes
  • stuck and going crazy
Sanja
Hello Kym,
What I suggest is actually creating a new index page that has the links to your respective sites. You will need to duplicate your original index page so that becomes your "home" page. Please see these instructions.
Then on the gateway index page, you could add a piece of code to remove the menu from that particular page. This code should do the trick:
<style type="text/css">
#main_nav {
display: none;
</style>
Now you can pretty it up and add the relevant links.
I hope that helps!
