Help! My tracking code isn't installed correctly.
  • Updated 7 years ago
Hi.. I was told (over at Google Analytics) that my tracking code isn't installed correctly here at my Yola Silver web site. .. As a result, Analytics is showing these pages as "restricted areas". My code needs to go into the head section of my pages immediately before the closing tag.. atm its sitting somewhere in middle of my page in a div
Where exactly is this to be found and how do I install it correctly?
Thanx a bunch,
Photo of Rosa Mystica
Rosa Mystica
  • 5 Posts
  • confused!
Posted 7 years ago
Photo of the_pete
  • 65 Posts
  • 16 Reply Likes
Official Response
Hey Rosa
This shouldn't be a problem at all.
You can open the 'Site Tracking Code' dialog though the the 'Site Properties' dialog under Site > Site Properties.
It allows you to add tracking code to the Header or the Footer of your site. In your case you'll be wanting to paste your Google Tracking code into the Header section on the right of the dialog.
Remember, this is a Yola Silver feature - so you'll need a subscription to use it.
