Help, my web site isn't working
  • Updated 10 years ago
My web site isn't accessible to others and I paid 19.99. My web address is www.petalsbookclub.com
Photo of Francie
Francie
  • 3 Posts
  • frustrated
Sanja, Official Rep
Hi Francie
It seems that you put on a password. If you take off your password, then people should have access. You can do this by going into your site manager which is the first tab you see. At the bottom of the page, you'll see "Site Password Protection" - click on that. Then, unclick the arrows you see to unlock your site. It should say "public" not "password protected"
Let me know if you still have problems.
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi Francie,
Littleus is correct. It seems that you have placed password protection on your site. If this was intentional, then people will need a username and password to access your site.
If you did not mean to add password protection, then you can remove it by following littleus' instructions.
Don't forget to click on the yellow "Update My Site" button after you have made any changes so that they will be applied to your live site.
Photo of Francie
Francie
  • 3 Posts
I don't see how to remove the password protection
Sanja, Official Rep
Francie.. did you read above how to remove the password?
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Your site is accessible now - looks like you successfully removed it!
Sanja, Official Rep
Yay.. you did it! =)
Photo of Francie
Francie
  • 3 Posts
Thanks everyone!
