help! need sound!
Has anyone added sound (mp3 file) to a site? And if so, how do I do it?
Photo of toby
  • 1 Post
  • frustrated
Photo of Peter
  • 2569 Posts
  • 113 Reply Likes
Hello Toby,
If you would like to add a single track to a webpage then you have a few options.
You can select a widget, for example Widgetbox or Google Gadgets from the Sidebar of your builder. When you select either of these a new dialogue will open and allow you to go into their product library. You can do a search for an mp3 widget. Select one that you like. Configure it for size, colour and sound file. You then need to copy the code that has been generated and paste it back into the place holder that was opened when you selected the widget brand. Then OK. Save your page, update and view. It should be there.
There are quite a few options on the configuration page of the widget such as repeat playing, automatic playing on entering the web-page etc. These need to considered carefully.
The last option is to simply drag the file to a place on your page. This will show the default icon and will work also.
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Toby,
Just to add to Peter's info, we have steps on adding music players on our help pages:
Let us know if you need any other help.
