help need urgent
  • Updated 10 years ago
  • Solved
My mail again wont receive mails?can you pls slove this,as I am waiting many important mails,thanks so much.(www.seedunia)
Photo of shirin.masood
shirin.masood
  • 9 Posts
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Shirin,
Your MX Records had been removed and I've re-added them to your domain's settings. Everything should be in order very soon.
Did you change your DNS Settings at all? The MX Records cannot be deleted from your domain's settings otherwise your mail won't work at all.
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
Why do things have to be so difficult? you send mail, you receive mail... no in between messing up settings and stuff.
