help pls, guestbook issue!
  • Updated 10 years ago
ive had a nightmare with guest books and messages i just want a page where visitors can comment or leave me questions or messages without loads of chat from public sites is there one if so pls pls let me know! thanks x
Photo of floss
floss
  • 30 Posts
  • frustrated
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi floss,
Check out this link: http://www.freecenter.com/guestbook.html - it has a list of free guestbook services that you can check out!
Photo of clouda9
clouda9
  • 323 Posts
  • 3 Reply Likes
Here is another link to a free guestbook...http://smartgb.com. It serves you best if you have a little HTML knowledge. Here is mine http://users3.smartgb.com/g/g.php?a=s...
Photo of CJ
CJ
  • 25 Posts
  • 1 Reply Like
Hello friend,
I have a answer to your q?, well for obtaining an solution create a form, design it thewayu want so your will make a way for the visitor to leave feedback, thanks vote or what uwish.
T.Y
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi floss,
If you want to use a message box widget that supports deleting of messages etc., you can try out a box at http://www.cbox.ws/
1. Go to http://www.cbox.ws/ and register for free.
2. You can then copy the code from the 'get the code' text area
3. Go to SynthaSite and drag and drop an HTML widget onto your page and paste your code into the HTML editor
4. You should then have a new box!
To administer the box (delete messages/block users etc.), simply log into http://www.cbox.ws/ click on the 'Admin' tab and then the 'messages' menu item on the left.
