help putting Accordion flash swf on yola
I am trying to get the free version of this flash thing to work on my site. http://www.flashtuning.net/flash-xml-...
So far, only geting a black box. http://pixelbox.co.nz/test-page.php
Does anyone know if it is possible or what i am doing wrong?
Many thanks
Richard
Photo of pixelshaw
pixelshaw
  • 27 Posts
  • 1 Reply Like
Photo of Justine
Justine
  • 751 Posts
  • 45 Reply Likes
Hello pixelshaw,
There are two ways to add components to your website. Depending on whether you want to add code, or if it's a file you need to add, you can use the HTML Widget or the File Widget. I have provided steps for how to do both:
If you are adding code, here's how to do it:
1. Drag and drop an HTML Widget from the sidebar on the right onto your page (the icon for this is a blue sphere).
2. An HTML editor will open up that will allow you to write or paste your code (use right-click > paste or Ctrl-V to paste).
3. When you are done, click "Save" and you will see the way that the HTML displays on your page
If you are uploading a file, here's how to use the File Widget:
1. Drag and drop a File Widget onto your page from the Sidebar on the right (the icon for this looks like a computer disk).
2. A dialog box will open and you can choose to upload a file or browse file manager. Please select which option you would like to use to upload your file.
3. When you click "OK" a link to your file will automatically be created. To test that it is working, save and preview your page.
I hope this helps!
