Help with a fly out please??
Guys Could realy use some help please, view this page and tell me how i can fix the problem
http://www.4-stepgames.com/xbox-games....
My flyout has white squares on the left of the flyout tag I got it from here
http://yolacodes.yolasite.com/vertica... /script
/head
body
div id="wrapper"
div id="leftcolumn"
Dropdown One
/div
/body
/html
script
var DDSPEED = 10;
var DDTIMER = 15;
var OFFSET = -2;
var ZINT = 100;
function ddMenu(id,d){
var h = document.getElementById(id + '-ddheader');
var c = document.getElementById(id + '-ddcontent');
clearInterval(c.timer);
if(d == 1){
clearTimeout(h.timer);
c.style.display = 'block';
if(c.maxh && c.maxh < c.maxh){
c.timer = setInterval(function(){ddSlide(c,1)},DDTIMER);
function ddSlide(c,d){
var currh = c.offsetHeight;
var dist;
if(d == 1){
dist = Math.round((c.maxh - currh) / DDSPEED);
}else{
dist = Math.round(currh / DDSPEED);
if(dist (c.maxh - 2) && d == 1){
}else if(dist < 1 && d != 1){
c.style.display = 'none';
Any help would be realy great thank you in advance.
style and script tags are in plaec just removed to show code and removed < and>.
Photo of Reader
Reader
  • 52 Posts
  • W8ing
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Hi, Reader,
I'm referring your question to our HTML team. Please allow at least 24 hours for them to respond. Thanks for your patience.
Photo of Jean
Jean
  • 134 Posts
  • 14 Reply Likes
I only know enough to be dangerous, so I might be a little off here. I think it's a measurement your css file. There are several class widths. Look at these three:
"left column" width is 225px (that's the left box)
"dropdown dd" width is 208px (the left dropdown list)
"dropdown dt" with is 188 (that's the flyout category list).
I think the problem is in the first one, "left column." Try changing the width to 208. If you see a change, it might not be quite the right number, but you'll know you're on the right track.
Hope that helps a little.
Sanja, Official Rep
Hello Reader
Have you been able to try Jean's suggestion? If you still have trouble with this, please let us know and we can assist further.
Photo of Reader
Reader
  • 52 Posts
Sorry for late reply been busy. Yes i have tryed this and it does not change the flayout. When i put the code in a doc file and set it to html its perfec. Could it be yola's code reader not reding it right. this is not the first flyout i have had trouble with. the other 1 came out in preview mode but when viewd on my site it did not work. all help greatly appreciated
Sanja, Official Rep
Hello Reader
Would you mind sending us an email to support@yola.com and we can assist further. Thanks!
