help with amazon product links
Hi can you look at my new site:
on the first page my amazon links are fine (ie when a customer clicks them they open up)
on the second page I cannot get the text links to open up in amazon - I have tried everything. I have had to change all my first page but would prefer it to look like the second page.
when in amazon I am selecting text only in product links and copying the html and saving the picture of the products onto my computer then I put a html box into my site and paste the html code. It all looks ok but a viewer to the site cannot open them up when clicked.
Can you help please
Thanks Mary
Photo of marydoll
  • 6 Posts
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
I can see the problem you describe.
Your links appear to be added correctly and if they are valid there is no reason why they should not work with SynthaSite.
Amazon would probably be in a better position to answer this one than us. However, if you would like to email me one of the links you added to, along with any instructions you received, I would be happy to check it out for you, just to make sure there is nothing obvious I can find.
Failing that you would need to contact Amazon for support.
