Help with "Emerald" theme?
I sue emerald theme because it is the widest them I could find. This them allows you to add a banner but when I try it is just a small banner. Is there a way to make a banner larger? or is there a theme a wide as emerald that will allow me to change banners.
If you could list all the wide themes? The reason I want it wide is because I like the 3 column websites and the wider the better.
Casey Stubbs--
Winners Edge Trading
Yola Blogger
Photo of Casey Stubbs
Casey Stubbs
  • 222 Posts
  • 6 Reply Likes
  • happy
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Casey,
The Emerald theme's banner is intended to tile across the top of the style and the recommended dimensions are 59x140px (I know they're currently hidden by the buttons on the style).
Other styles that may suit you:
- Tastelessly
- Clean Slate
- Red Planet
We have a style guide that may also assist you to decide which style to use: http://www.yola.com/yola-style-guide.
I hope that helps!
Photo of Angela Spencer
Angela Spencer
  • 86 Posts
  • 1 Reply Like
Hi
I tried to load the image at 59x140. It looks terrible - the image is a tiny block on either side of the banner. This can't be right!
Sanja, Official Rep
Casey, it seems that you may be able to add a big banner after all. Please look at the example in this thread:
http://getsatisfaction.com/yola/topic...
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
hey Casey, I'm having the same problem too... but kind of solved it. When you open the add banner and select it from your file manager, it'll pull up a small square only selecting part of your banner... DO NOT press ok... instead, press the cancel button and it'll insert the whole thing. But it'll still tile it... so the banner MUST be the exact length or bigger than the length of the page or the difference it is short, It'll tile.
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Thanks guys - good to know there's a workaround :)
Sanja, Official Rep
I gotta ask Marije - how do you pronounce your name?
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Ma-ray-ya (different to the look!)
Sanja, Official Rep
Soo pretty! =) I knew that the j would make a Y sound.. but I wasn't sure how you put it all together. I love it! =)
Angela Spencer
  • 86 Posts
  • 1 Reply Like
Eish people, I put the image in exactly as specified and then it tiled it. I don't want it to tile though. Tiling suggests that the image is too short to fill up the whole space and it should be repeated. How do I switch that off?
Many thanks
Angela
Photo of papa
papa
  • 327 Posts
  • 20 Reply Likes
gave this answer and tried it on a test site yesterday. Making the image large enough to fill the banner space some of the image was lost.
http://forum.yola.com/yola/topics/ban...
You can see how the image change from the original size to an expanded size.
The other images on your site fit well.
You have a wonderful site. Good luck with the image.
http://test3.yolasite.com/
I increase the size threw "paint" to 140% under image to attributes. Lost some of the pictures but it worked. Not a good either.
papa
Photo of papa
papa
  • 327 Posts
  • 20 Reply Likes
try resizing to 1008x140 instead of 59x140
papa
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi All
I discussed this with our developers and apparently there is no way to prevent tiling on the Emerald style in it's current implementation. We would have to create another version of the same style but that would cause problems for people who are already using it. We need to build in the ability to have different people use different versions of the same style and that is still some ways off for us.
For now I recommend avoiding this style if you don't want a tiling effect on your banner image. Our apologies!
