help with hit counter
I hope this isnt a dumb question but I dont understand how to open the filie to my web page to place code on it for my hit counter can you please help me
Photo of rolando caballero
rolando caballero
  • 23 Posts
  • unsure
Photo of Ellie
Ellie
  • 38 Posts
  • 1 Reply Like
Hi Rolando,
You can try this:
1. Go to file manager
2. Right-click on your file then press unzip.
If that doesn't work try this:
1. Insert a file widget and put your file there.
2. Hit page preview
3. Click on the file link and select open
4. A link should appear, opening the content of your folders
Ex. - Image, Html
5. Click the one where it contains the necessary code
6. It should lead you to another page, showing the result of the code.
7. Hit page source.
8. Copy the code and erase there: <!-- and -->
9. Insert the code into a html widget
10. You're done.
I hope this helps.
Ellie
rolando caballero
  • 23 Posts
hey littleus i found the html widget but the site for my hit counter says to place the code between the body tags and there not there also i cant seem to paste my copied code to the html editor can you tell me how to do this
Sanja, Official Rep
@Ellie - Thanks for sharing your suggestions. =)
Hello Rolando
Are you trying to paste in the HTML code for your hit counter? If so, then you can drag an HTML widget from the right-hand side, under "Content", and place your code in there.
Please let us know if you need further assistance.
rolando caballero
  • 23 Posts
hey littleus i found the html widget but the site for my hit counter says to put the code in between the body tags but they arent there also i cant seem to paste the code on to the html editor how do i do this
Sanja, Official Rep
Yes.. you don't need to worry about the body tags. You just need to add the code to the HTML widget. You can try pasting by right-clicking on your mouse and clicking on "paste" or you can try using CTRL-V to paste as well.
rolando caballero
  • 23 Posts
thanx ill try this and get back to ya
rolando caballero
  • 23 Posts
thanx for the great advice and making your instructions simple to follow you are the man
Sanja, Official Rep
I'm glad that it worked for you. =)
