Help with how to use Adsense.
Say I want to add 6 ads to one page, would I create a 6 different ads to get 6 different codes for that page? Or do I create 1 ad and get 1 code and use that in the 6 different spots.
Also, some adds aren't showing up on my pages. It seems like only the top 3 ads per page are showing up and the rest have just blank spaces.
Thanks for any help.
Photo of kufta4
kufta4
  • 4 Posts
  • 1 Reply Like
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi kufta,
This is likely to be a Google Adsense intelligence question.
There may be people here who have the answer but in the meantime I would locate the Google Adsense Knowledgebase, FAQ and forum. You will get the most reliable up to date info from those sources while waiting for a possible answer here.
This will probably take you a fair bit of time to work through but the knowledge you gain is really valuable and you may even like to become a contributor here with learned knowledge of Google Adsense as it relates to Yola. I hope you do.
Photo of kufta4
kufta4
  • 4 Posts
  • 1 Reply Like
Thanks for the answer. This might help some others and its a bit disappointing.
"3 ad units, 3 link units, 2 search boxes max"
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Bad luck! but I guess the bright side is that you no longer wonder :)
Thanks for finding and taking the time to report this too kufta. It really does help.
