Help with images that aren't appearing
  • Updated 10 years ago
Good afternoon!
Some pictures that till yesterday I could see normally are now with a ? signal.
Does somebody know whats going on?
Thank you
My website: http://carlaladob.synthasite.com
Photo of carla lado b
carla lado b
  • 50 Posts
  • 1 Reply Like
  • worry
carla lado b
  • 50 Posts
  • 1 Reply Like
Is it normal to synthasite users?
Sanja, Official Rep
You should not have problems with your images. This indicates there is some kind of error.
I wonder if it has to do with the language style used in your file names. For example: src="resources/chapeuzinho sanguĂ­nea site copy.jpg There is an accent over your "i" in sanguinea If you change the file names using the english lexicon, then your images should show up again.
carla lado b
  • 50 Posts
  • 1 Reply Like
Well, everything was fine till yesterday... But anyway I will have a look on the accent thing...
thank you
Sanja, Official Rep
Sometimes that can happen. Things will appear to be fine for awhile, then it realizes... hmm.. something's not right and it starts to act up. Hopefully this is only reason for why your images are not showing up. Please get back to us if you continue to have problems.
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hi there carla labo b,
Yes littleus, you are correct, renaming the image so that it does not have the accent will solve the problem.
You can rename your images by:
1. Go to the File Manager
2. Right click on the image you want to Rename
3. Click Rename
Please let us know if you need further assistance.
Emmy
