Help with Metcalfe Video Widget - Please help!
Hi
I am trying to use the Metcalfe Video Widget to display a scrolling set of pictures of my jewellery. I have created it in 'Sets' in Flickr and I have copied the URL and code and put it into the widget URL line. The issue I am having is that it works as I want it to in edit mode, but when I save and then preview the page the video window is blank and will not play.
I can't find anything other than Metcalfe widget that will do what I want.
Any help would be gratefully received as I am obviously doing something wrong!
Thanks
Photo of A
A
  • 87 Posts
  • 1 Reply Like
  • frustrated!!!!!!!!!!!!!!
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi A,
This may be an issue with "preview". I suggest that you publish your site and see if it works in the published version?
