hi, is there any problem if i post articls in arabic languege ?
  • Updated 4 years ago
Photo of HABEEB
HABEEB
  • 3 Posts
Posted 4 years ago
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello Habeeb,
Alternative scripts work well with Yola built sites. The issue may be the direction of the flow of writing. If this is the case then you can create your text in a word processor, copy that text into something like "Notepad" to strip any invisible RTF commands which are embedded by word processors,  then finally copy and paste that directly into your page.
I played around with some Arabic text sometime ago and the process I mentioned seemed to overcome direction issues.
You may like to check this older thread:
(Edited)
Sanja
Hi Habeeb,
Gop is correct. Yola supports UNICODE, so you should be able to add text in the language of your choice, as long as you have the necessary keyboard and browser settings. This means, you can use Arabic if you wish!
