Hosting questions - noob needs help
  • Updated 7 years ago
Please Help! I set up my site www.mishababi.com with the domain at godaddy.
I then decided to get hosting from godaddy. Then my site stopped working. Is it because of the hosting?
I'm a total noob so someone please tell me what is wrong and how to fix. I will be eternally grateful. Thanks!
Photo of taitainorman
taitainorman
  • 2 Posts
  • confused
Posted 7 years ago
Photo of Justine
Justine
  • 751 Posts
  • 45 Reply Likes
Hello taitainorman,
I'm sorry to hear you're having a problem with your site. I have visited it, and can see the homepage - I've attached a screenshot of it - could you let me know if this is the right page?
If you could also let me know what you are seeing (such as an error message) when you try get to your page, it'll help us find out what could be causing the problem.
Thanks!
taitainorman
  • 2 Posts
Hi Justine.How very strange-i had the typical 'something exciting coming soon' page. Thank you for the quick response. It seems to be working now. I do have a very stupid questions so excuse my ignorence - where is it hosted now? Is it with Yola or Godaddy? How do I check this?
Stupid question, i know.
Photo of Justine
Justine
  • 751 Posts
  • 45 Reply Likes
Hi taitainorman,
I'm glad your site is working. Sometimes it takes a while for changes to your domain's settings (such as IP addresses) to propagate, and that might have been why you weren't able to see your site.
I can confirm that your site is hosted by GoDaddy. I used a website called: http://whois.lanctrl.com/ to check this - you can just type in your web address and it will provide you with that information.
Hope that helps!
