how to disable right click?
If i cannot access head html how do disabled right click on my website?
Photo of david
david
  • 20 Posts
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
add the code in a html widget at the top of the page - see if that works.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
do it on a test page first
Photo of david
david
  • 20 Posts
That didnt work mate, don't know what to do now?
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Thanks Lee :)
David - if you can try adding the code using the HTML widget and dropping it at the very top of the page. It often works. Alternatively, perhaps this post will assist you: http://getsatisfaction.com/yola/topic...
Photo of david
david
  • 20 Posts
Adding the code using the HTML widget and dropping it at the very top of the page. doesnt work. Thanks anyway...i'll probably watermark my images. Cheers.
