how to tweak column? Need advice ASAP
Yola is the best site builder ever..I'm currently trying to create my own site. But there is certain problem that I would like to seek some help...let say if I choose to have three what we all know, yola by default divided this column into exact same width if I want to make a little adjustment and make the center column to be a little bigger than the other two? and let the left panel smaller than the right panel? please give me an advice...thank you..
Photo of joshuanirza
  • 2 Posts
  • frustrated
Photo of JC
  • 354 Posts
  • 15 Reply Likes
in answer - use the column widget on right hand side, can do lots and lots by doing this. Drag a column widget across, then drag other column widgets and place inside the first column you dragged (sometimes a third if necessary) - then inside those column widgets you then pull across text boxes and place inside where you want.
Click on the lines going down between and you can 'pull' the columns wherever you want back and forth across the page.
Easy. these are great and really are wonderful in that they give whatever spacing you require.
Hope this is what you are after.
Oh, depending on the layout you chose, this is easy. Sometimes the layouts you choose which give columns only can't be added to (ie putting column widgets where you want). so much better to choose simple layout, and then you can add/change whatever you like in the way of columns by using the widgets.
Photo of smithy
  • 1222 Posts
  • 28 Reply Likes
you can either add a 2 column widget to your page and then add another 1 inside that 1. i know what u mean by what u jus said i don't think u can do it. what jenC said about the 2 column widget is right. you can do lots of things with the 2 column widget.
