Huge BUG/Problem With Site!
  • Updated 11 years ago
  • Solved
Dear SynthaSite Employees,
I'm having a huge problem. Well on my second site http://www.aawblogs.synthasite.com there's a weird bug. Well you see when i open my site to edit it the site gives a weird error code: Now i think ok maybe it's a temporary glitch. So i just click new page and create a new page and the new page is fine. Well the index page is still screwed up! I can't open it. When i update my site and go to my site an error code shows: Code: Warning: Smarty error: unable to read resource: "templates/Greenygrass/layouts/Default/template.html" in /srv/exports/sites/D879/D4c0/D842/D530/U8a4986cb1cfc9f15011d0352480c4978/1226771090/8a4986cb1cfc9f15011d0352480c4978/classes/commons/lib/smarty/Smarty.class.php on line 1095
BUT theres a glitch also. if you type in http://www.aawblogs.synthasite.com/fa... it works! BUT my index page crashes. And remember the first image? Well when i open my site to edit it that image shows and that image was of the site i delete a month ago. And when i open another page it's fine and normal. Any help or bug fix? Thanks i'd appreciate it.
Photo of Rjun
Rjun
  • 100 Posts
  • 3 Reply Likes
  • frustrated
Posted 11 years ago
Photo of Rjun
Rjun
  • 100 Posts
  • 3 Reply Likes
Any suggestions?
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi Rjun,
From the error's on your site, it seems as though you might have invalid HTML on your site. Please can you send a support ticket to support@synthasite.com with your account details, so we can help you fix your site.
Please don't post your account details here, please email it to us.
I await your email.
Kershnee
Photo of Rjun
Rjun
  • 100 Posts
  • 3 Reply Likes
There is no invalid html it's jsut a blog post on the index page i still sent an e-mail to the support
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Thank you - will we investigate and get back to you.
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Here is something you can try:
switch to any other style - then switch back again to your original style and update your site.
The bug seems to be related to the style sheet. Let us know if that resolves the problem.
Photo of Rjun
Rjun
  • 100 Posts
  • 3 Reply Likes
Monique It Worked! Thank you so much! You also helped Kershnee I am so happy now!
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Glad to hear it. This should not happen and we will of course try to fix the bug, but if it ever does happen again try this trick. If that does not correct the problem let us know, of course!
