I can't upload images I have a big problem in my computer-plz help
  • Acknowledged
hi every body,
i think i have a big problem in my computer. i can't uplaod images these days and i don't know why. i was able before. when i choose i pic to be uploaded i don't see any uplaoding progress. at first, i thought it was a problem with yola system. but, when i opened my other site in weebly and chose a pic to be uplaoded the uplaoding progress didn't move. then a message appears ( uploading error... please try again)
i tried for many days but the problem still there. i don't know what to do.
i think the problem in my computer , beacuse i cant sign in to yahoo messenger and msn messenger, too.
so, what does that mean????
what has happened to my computer???
what do you think is wrong ??
i hope you help me because i really feel saaaaad for this, i want to build my site. but the messenger i can sign in to it from meebo. and that worked.
thaaaaaaaaanks
Photo of Sally
Sally
  • 46 Posts
Photo of KanThaiDecor
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
Are you using a PC with windows XP or Vista?
Photo of Sally
Sally
  • 46 Posts
windows xp and i use firefox 3 and i have flash 10
Sanja, Official Rep
This is my recommendation but I do not know if this will resolve your problems. I would uninstall your firefox completely. Then, install Firefox again - you can do the same version or a newer version. This is what I had to do when I ran into problems with my images. Since doing that, I have not had any problems. Perhaps this will be the same for you?
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Thanks Littleus - I'm hoping that this will solve the problem.
Touleen, you can also try someone else's computer and if it works, you'll know that the problem lies with your machine specifically.
Photo of Sally
Sally
  • 46 Posts
ok i wil try now this, and thanks for you for helping me
i tried now to download Safari to see if it good but when the browser opened this apeared to me:
Safari can’t open the page.
Safari can’t open the page “http://www.apple.com/safari/welcome/”. The error is: “There was a problem communicating with the web proxy server (HTTP).” (CFURLErrorDomain:306) Please choose Help > Report Bugs to Apple, note the error number, and describe what you did before you saw this message.
and when i use internet explorer the page does't display and says there is a problem
so what does that mean?? and what is the proxy???
thanks for you all
Sanja, Official Rep
Touleen... in your Firefox, can you please type in the following in your address bar: about:plugins Then, take a look at what flash programs are installed. Perhaps you have more than 1 flash program and that is interfering with how things are running.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
Touleen - you can easily rule out the fact that its a problem with your account by uploading from another computer. It sounds to me like your computer is ill - try and install the programs i suggest above.
If you are unable to upload images from a newly installed firefox and you have the latest flash installed the problem must be from the PC being infected with spyware or a virus.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
or its a registry issue - if you install CCleaner ther eis a option to clean the registry of your PC.
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
What bothers me is not being able to sign into yahoo, msn messenger and all of this at the same time.....I am thinking the computer is ill as well.
Photo of Sally
Sally
  • 46 Posts
yes, it must be ill John. i'll buy another one soon ^-^
Photo of Sally
Sally
  • 46 Posts
hi for you all
thanks for helping me
littleus i did as you told me and i found all of these, they are sooo much OMG:
QuickTime Plug-in 7.6.2
npqtplugin7.dll
npqtplugin6.dll
ا npqtplugin5.dll
npqtplugin4.dll
npqtplugin3.dll
: npqtplugin2.dll
npqtplugin.dll
Mozilla Default Plug-in
npnul32.dll
Default Plug-in
Shockwave Flash
NPSWF32.dll
Shockwave Flash 10.0 r22
iTunes Application Detector
npitunes.dll
iTunes Detector Plug-in
DivX® Content Upload Plugin
npUpload.dll
Picasa
npPicasa2.dll
Picasa plugin
Yahoo Application State Plugin
npYState.dll
Yahoo Application State Plugin version 1.0.0.7
Windows Live® Photo Gallery
NPWLPG.dll
NPWLPG
RealJukebox NS Plugin
RealPlayer(tm) G2 LiveConnect-Enabled Plug-In (32-bit)
RealPlayer Version Plugin
RealNetworks Rhapsody Player Engine
Java(TM) Platform SE 6 U13
Java(TM) Platform SE 6 U11
Adobe Acrobat
Microsoft® DRM
Windows Media Player Plug-in Dynamic Link Library
Microsoft® DRM
Sanja, Official Rep
I believe you're good Touleen. I don't see another instance of a shockwave Flash. I would suggest that you try UK Duke's advice and please do try from a different computer to see if this yields the same problems.
Photo of Sally
Sally
  • 46 Posts
UK Duke , i have kaspersky to protect my computer
Photo of Sally
Sally
  • 46 Posts
littleus, do you mean that my plugins are ok?? or what?
should i download shockwave Flash??
I'm afriad if i downloaded the protection programs that UK Duke gave, i would have too many protection programs because i have also kaspersky to protect my computer
and i don't have another PC to try from it
Sanja, Official Rep
It would appear that your plugins are okay. You already have shockwave Flash on your computer according to the list you posted. so.. that should not be an issue. I was looking to see if you had more than 1 shockwave flash installed. It doesn't appear to be the case.
As for another PC to try it from.. perhaps you can use a friend's computer? This will help to determine if the problems are in fact related to your computer or to the site builder. I'm inclined though to believe that the problems lie in your computer. I would take your computer into a store to get it checked out. I'm sorry Touleen that I don't have other solutions. I hope others on this forum may be able to suggest alternatives.
Photo of Sally
Sally
  • 46 Posts
thaaaaanks for trying helping me. and i can't go to my friends now. it is now 10:29 P.M ^_^
Photo of Sally
Sally
  • 46 Posts
i checked now my computer protection from kaspersky and i found that it is in danger and i fixed it, but i still can't upload images
Photo of fairuz
fairuz
  • 1 Post
hi
i got a problem sharing and sending any file in yahoo messenger ,
problem occurs after using kapersky anti virus 2010
do somebody help me
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
try and disable the anti virus software see if that helps.
