  • Updated 7 years ago
Hi, i have a site :http://homejobnofee.yolasite.com.I have a problem with my HTLM can you please help?
Photo of alnk999
  • 1 Post
Posted 7 years ago
Photo of Brianna
  • 2045 Posts
  • 92 Reply Likes
Hi alnk999,
Please share the exact page on your site and error you are seeing with your HTML. We'll be happy to help!
Photo of Shawn Holman
Shawn Holman
  • 486 Posts
  • 26 Reply Likes
Hi Alnk999,
I can't access http://homejobnofee.yolasite.com.I
Could you give us a screenshot if the page with the HTML problem so I can just see it and try to tell you the problem and find a solution
How to take screenshot:
If your using Windows, there is a Snipping Tool you can use to take screenshots
If your using Mac, I suggest Jing
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
Hi alnk999,
I am able to access http://homejobnofee.yolasite.com/
Can you please share the URL to the page that you're seeing an error and the error that you're having? I don't see any errors on your homepage.
Kind regards,
