I have an annoying problem going on, grrrrrrr
I am unable to delete some widgets? Have tried in explorer and firefox and signing out and back in again, they just won't shift, any light shed on this would be a great help ;)
Also, how do I get to my site builder now that the Yola button is gone. lol, ha, I'm slightly confused.
Thanks Guys!
Margaret
Photo of Margaret
Margaret
  • 9 Posts
Photo of Connor McCarra
Connor McCarra, Champion
  • 944 Posts
  • 47 Reply Likes
Sounds like the doing of some bad code. First try and remember the last code you added before it all went wrong, then click on edit on the html widget and clear all the code (or copy and save it to notepad and clean it up later, if you want to add it again).
Hopefully this fixes it.
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Margaret,
Can you post your site's URL and let us know which are the problem widgets? Then we can take a look.
To login to your account, you can go to www.yola.com and enter your login email and password into the fields in the top right of the screen.
